shaking problem
Old Nov 16, 2004 | 12:16 AM
red2k1gt's Avatar
red2k1gt
Default shaking problem
i have a 96 auto V6 and whenever i stay low on the throttle up through the gears i get a horrible shaking coming from the back end as it shifts. When i get on the gas and go through the gears it doesnt seem to do this. Can someone tell me whats causing this?
Old Nov 16, 2004 | 12:18 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: shaking problem
Dunno... maybe you need new shocks. LOL
Old Nov 16, 2004 | 12:22 AM
red2k1gt's Avatar
red2k1gt
shocks...?
Old Nov 16, 2004 | 12:39 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Well unless your rearend is going out I really dont know what else it could be... so I threw that out there. LOL
Old Nov 16, 2004 | 12:53 AM
Dan04COBRA's Avatar
Dan04COBRA
Driveshaft could be the problem, control arms could be the problem. Your transmission not kicking down when it needs to could be the problem.....
red2k1gt's Avatar
red2k1gt
by rear end going out do you mean gears (please say its the gears), or the whole rear.
Old Nov 16, 2004 | 12:56 AM
red2k1gt's Avatar
red2k1gt
by rear end going out do you mean gears (please say its the gears), or the whole rear. Any other opinions?
Old Nov 16, 2004 | 12:58 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Well usually when the gears go bad you will get a grinding and whining noise.
I didnt think it was the driveshaft because usually if you have a bad ujoint then when you hit the gas it makes one bump and then its pretty steady from there, but if the whole drive shaft is bent then it will definetly shake. Im assuming the bushing on the control arms could be bad... and the tranny not kicking down usually wont make a bad shaking, it just wont upshift at the right time. But I could be wrong.
Old Nov 16, 2004 | 01:07 AM
red2k1gt's Avatar
red2k1gt
i wouldve never put control arms in the mix when the grinding is only during shifting, thanks for the opinion. I would really like some other opinions though if anyone else has them. Thanks
Old Nov 16, 2004 | 03:10 AM
slo93aod's Avatar
slo93aod
looked at the u joints??
