having a problem
Old Mar 28, 2007 | 05:31 PM
dstrbdbyu's Avatar
dstrbdbyu
Default having a problem
i have a 1992 convertible, 2.3, and im having all kinds of problems with it right now. its idling very low and sometimes stalling out, engine shakes, sounds terrible, when i hold the brake to shift into drive, park, etc. ive been going thru alot of gas, barely gettin 10-12 miles per gallon. i have changed the o2 sensor, spark plugs, plug wires, mass airflow sensor, pcv valve, fuel filter, egr valve and the sensor that attaches to it, among other things, thats just all i can remember at the moment. its still runnin terrible, i can barely get to 55 mph and to get to that takes forever. ive had the transmission checked, i just had a new one put on less than 4 yrs ago and everything checks out. i had all new exhaust pipes, muffler, everything except the catalytic converter, put on less than 6 months ago. its almost like it isnt getting the fuel it needs to go. does anyone have any ideas what this might be?
Old Mar 28, 2007 | 06:39 PM
TwotoneVert's Avatar
TwotoneVert
Default RE: having a problem
Have you checked the fuel pump or (I am not sure if the the 2.3 has one) the IAC?
Old Mar 28, 2007 | 06:46 PM
dstrbdbyu's Avatar
dstrbdbyu
we tested the fuel pump, it shows the pressure as 32, i had read somewhere it was supposed to be around 39-42...would that be enough to make it run this way? i dont know what the iac is???
Old Apr 2, 2007 | 07:51 AM
kenv's Avatar
kenv
Does it have a MAF?. When they go bad they will cause the car to run like that. Also check for vacuum leaks.
Seanam
Oct 4, 2015 10:15 AM
marc954
Sep 29, 2015 03:05 PM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
