WTF???????????
Old Nov 20, 2004 | 03:35 PM
deesgt's Avatar
deesgt
Default WTF???????????
So I was just out running some errands. I stopped at the car wash to vacum my car and decided to spray it off. All was good. I left and drove home (10 min. drive) when I got home I remember getting out the car and looking at the rear and thinking "LOL! looks like my car is lowered". Then I looked at the front wheel and it was at the normal stock height. WTF? So I went and looked at all the wheels and 3 are normal but the driver side rear looks like someone put a lowering spring on. Did my shock just give out? Can that happen? It was in a ten minute span that this occurred. I pray it IS just a shock. What other components in the rear suspension could cause an abrupt drop in ride height like that? Please help [>:]
Old Nov 20, 2004 | 06:50 PM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: WTF???????????
Sounds like a bad shock.
Old Nov 21, 2004 | 01:49 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
If the shock goes out you will know it. Thats what it sounds like but I had an F350 that had two bad shocks and the front wheels hopped off the ground with every bump I hit. Also, the steering was really loose also.
Old Dec 1, 2004 | 11:01 PM
thelast50ho's Avatar
thelast50ho
shocks dont efect the ride hight at all when they go bad. Id check the spring to see if it broke. on my car when i put lowering springs on it i found that both front springs were broke. So that would be my guess
Old Dec 2, 2004 | 02:10 AM
fastmustangs1's Avatar
fastmustangs1
Sounds like a blown shock. Replace it and u will be ready for action.
Matt
Old Dec 3, 2004 | 02:21 AM
stieny's Avatar
stieny
ORIGINAL: thelast50ho
+1
Old Dec 3, 2004 | 02:04 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
if you want to mod the suspension now is the time. it completely justifies spending money.
Old Dec 4, 2004 | 02:25 PM
Dan04COBRA's Avatar
Dan04COBRA
I guess you've never seen a car with blown shocks. Have you ever thought of why they make adjustable shocks for the guys who like to adjust ride heights for looks...?
Old Dec 12, 2004 | 01:14 PM
roundman's Avatar
roundman
it's easy enough to pull the shock you think is bad and check it out. if it's real easy to compress compared to pulling it out, then replace it for sure. you might also want to take a close look at the entire rear suspension and make sure nothing else is broken or cracked like the control arms or torque boxes too.
xdef00
Feb 27, 2004 03:18 AM
