Bench test electric fuel pump?
Old Apr 5, 2007 | 11:29 PM
Maddogg's Avatar
Maddogg
Default Bench test electric fuel pump?
Gottaoriginal '88 GT with no fuel pressure. Think my fuel pump is bad.
I'm sure the problem is related to the fuel pump itself cause I've replaced the fuel filter,
replaced the relays, & checked fuses & the inertia switch(not tripped).
Thought I could just install a universal in-line electricpump on the outside & it would work, but the ones I was thinking of were only for carburated applications & still out of my price range.
If I remove the tank & pull out thepump,could I test itby hooking up 12volt straight to it? The only electrical tools I have is a test light & can't afford to buya pump just to see.
Any input would be greatly appreciated.
Old Apr 6, 2007 | 01:36 AM
tinman's Avatar
tinman
Default RE: Bench test electric fuel pump?
I don't see why you couldn't.
Get the battery and use a couple of test leads, I'd ground it first.
DO NOT run the pump very long as they are cooled by the gas in the tank, get it too warm and it's killed.
I also think if the pump runs, it should be ok.........
I've tested many electric pumps this way before but not any 'in tank' types......
Old Apr 6, 2007 | 10:55 PM
Maddogg's Avatar
Maddogg
Yes! Thanks!
I had a bad pump.
Tested it & got nothing.
Forgot about my credit card, so I bought one.
Installed it & started pumping, but does this without the key in or the switch on?!?
As soon as the battery was hooked up the fuel pump started humming & won't stop.
A noticeable hissing sound is emerging from around the intake manifold, but can't detect any external leaks.
Could an injector (or something) be stuck open causing the pump to continuously run?The car will just barely stay running & won't for very long. Idle is very rough, & remember this mustang running like this before it died.I think this maybe the reason my old pump went out.I makes this hissing noise even without the key in.
Old Apr 7, 2007 | 11:58 AM
Chopper's Avatar
Chopper
Could be a bad fuel pressure regulator.
Old Apr 9, 2007 | 07:04 PM
richinwa's Avatar
richinwa
Dude you have a stuck relay! Look for the green relay that is next to the brown on and disconnect it before you burn up your pump! When you turn on the key without starting the engine the Brown EEC relay energizes the Green fuel pump relay for a couple of seconds to get fuel pressure to the lines. Once the engine starts to turn over the PCM gets a pip signal from the distributor and energizes the Fuel pump relay till it loses the pip signal. You can also unplug your TFI module on the distributor and see if that turns off the pump, if that does then you need a new TFI and Stator.
Old Apr 9, 2007 | 09:07 PM
Maddogg's Avatar
Maddogg
ORIGINAL: richinwa
EverythingI needed to know & then some!
Yea,I got a bad relay.
Thanks!!!!!!!!!!!!!!!!!!!!!
Old Apr 9, 2007 | 10:00 PM
luckythirteen13's Avatar
luckythirteen13
so after all this, is it working yet?
Old Apr 10, 2007 | 01:04 PM
richinwa's Avatar
richinwa
Kinda fingered that one.
1TUFF302
Nov 5, 2015 04:02 PM
9550
Oct 26, 2015 05:01 PM
uberstang1
Sep 20, 2015 06:42 PM
SteelerNation82
Sep 16, 2015 07:11 AM
jaiidutch
Sep 14, 2015 10:29 AM
