Adjusting your clutch
Old Nov 23, 2004 | 12:48 PM
STKClutch's Avatar
STKClutch
Default Adjusting your clutch
As some of you may know i just picked up a 98 cobra about a month ago. Was reading the book on how to adjust the clutch, it said to just pull up on the pedal so i did. I didnt hear a click or anything but it comes up about an inch or two, but does not stay in place?
Old Nov 23, 2004 | 01:20 PM
Birdieman4's Avatar
Birdieman4
Default RE: Adjusting your clutch
Do you want the clutch disengagment point up higher on the pedal? If that is what you're after, then what you need is to replace the hydrolic clutch with a cable, after which you can set the disengagment point whereever you want it. If you do this, replace the crappy plastic quadrant with a billet piece. The plastic quadrant is a piece of ****. As far as ajdusting the clutch pedal stock, you are doing everything right except maybe pulling the pedal aside a little before pulling back on it. This hardly makes any 'real' adjustment at all. For big adjustments get a manual cable.
Old Nov 24, 2004 | 02:28 AM
STKClutch's Avatar
STKClutch
ok i just ordered 1 thanks
Old Nov 24, 2004 | 03:05 AM
cammedlx's Avatar
cammedlx
i never thought a mustang had a hydraliuc throw out bearing i though they all was cable
Old Nov 24, 2004 | 10:35 PM
fullthrottle's Avatar
fullthrottle
i thought it had to be in 1st gear when you do that? That's what my book said, don't know if it would make any difference.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
junior04
Sep 28, 2015 10:53 AM
