B&M Shift Kit Install help
Old Nov 20, 2004 | 11:51 PM
Johnny5.0's Avatar
Johnny5.0
Default B&M Shift Kit Install help
Hi I am planning to do a shift kit install on my friends AODE in his 95. Its the B&M shift improver kit #40264. Well I think I can do it but Im a little skeptical on the 1-2 accumulator. It talks about needing an Servo Piston remover tool.. but it said experienced transmission techs should be able to remove and install the 1-2 accumulator without the use of the tools. What do you think? Am I going to need this tool. Also any websites with an install would be great. Its hard to make out the pictures in the included manual in the kit. Thanks in advance.[&:]
Old Nov 21, 2004 | 01:08 AM
luckythirteen13's Avatar
luckythirteen13
Default RE: B&M Shift Kit Install help
man, id never open my transmission. all i can say is be carefull
Old Nov 21, 2004 | 01:31 AM
20vVolvo's Avatar
20vVolvo
wut bout not doin it buy yourself...with dealership?
Old Nov 23, 2004 | 03:11 AM
Johnny5.0's Avatar
Johnny5.0
wow great answers guys! Good thinking there..
Old Nov 23, 2004 | 07:55 PM
11seccobra03's Avatar
11seccobra03
get the tool it will make it a-lot easier for u
Old Nov 24, 2004 | 10:59 PM
Mach1_04's Avatar
Mach1_04
All you need is a pair of snap ring pliers and a hammer.Use the hammer handle to hold pressure on the servo,remove snap ring,if servo does not come out easily,use a pair of channel locks to wiggle and it will come out.I think you are replacing the spring\springs,you will then have to remove valve body and replace other springs.good luck hope this helps.
drfister
May 3, 2018 10:38 PM
SYNY5TER
Sep 2, 2015 01:35 AM
Sep 1, 2015 08:16 PM
kawiguy827
Sep 1, 2015 07:09 PM
Tyoung68
Aug 25, 2015 04:31 AM
