engine hoist question
Old Nov 23, 2004 | 08:14 PM
mkspeed26's Avatar
mkspeed26
Default engine hoist question
well, i got an engine hoist from school so i can pull the 351W out of the thunderbird and put it in the stang over break. well, i assembled it and tried to extend the cylinder, but it wont budge. the plug in the bottom is tight and i am going the entire range of motion of the handle. i think it is low on fluid. does anyone know how to fill the cylinder with hydraulic fluid?
Old Nov 23, 2004 | 08:59 PM
619socalstang's Avatar
619socalstang
Default RE: engine hoist question
should be a rubber plg on the housing about half way up may be painted the same color pull it out and fil to overflow, or a claerly marked fill hole. You can also pull the bleeder valve out and force the fluid in that way and repalc eit quickly. GOOD LUCK.
Old Nov 23, 2004 | 09:33 PM
mkspeed26's Avatar
mkspeed26
ORIGINAL: 619socalstang
thats what i thought it was, but i wasnt sure and i didnt want to f*ck it up. thanks
Old Nov 24, 2004 | 09:32 AM
wiseguy's Avatar
wiseguy
I know on my cylinder, you unscrew the release valve and fill it through there. My hoist is a Bluebird that's about 15 years old, so your cylinder might be different.
Old Nov 24, 2004 | 03:24 PM
mkspeed26's Avatar
mkspeed26
well, its still f*cked up. im just gonna borrow a cylinder from a friend and see how that works. its raining anyways today, so i cant do any work now.
GimpyHSHS
Aug 29, 2015 06:30 PM
classic69FB
Aug 12, 2015 11:58 PM
$A_Money$81
Aug 11, 2015 01:30 PM
HIS S-197
Aug 10, 2015 05:47 PM
