c4 vs. c6
Old Nov 27, 2004 | 07:24 PM
mkspeed26's Avatar
mkspeed26
Default c4 vs. c6
attached to my 351W is a ford automatic tranny which i believe is a c4. it got me thinkin. i was just wondering what the differences are between the 2, both visually and performance wise. thanks
Old Nov 27, 2004 | 09:44 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: c4 vs. c6
c6 is stronger... but heavier and sucks more power - overkill but for all the baddest of the bad engines...c4's can be quite strong
Old Nov 27, 2004 | 10:05 PM
fuzi0nz's Avatar
fuzi0nz
o i thought this topic wuz on corvettes
Old Nov 28, 2004 | 12:46 AM
roundman's Avatar
roundman
it's easy to tell the difference between the two, the bell housing on the C-6 tranny is integral with the tranny and cannot be removed separately where the bellhousing on the C-4 can be removed from the tranny with 4 or 5 bolts taken loose. joe is right about the C-6 being the big bad tranny that came behind the big blocks and the 351 Cleveland engine I think. most racers prefer a well built C-4 since it's much lighter and has less frictional power losses internally compared to the C-6.
Old Nov 28, 2004 | 09:46 AM
FoxGT's Avatar
FoxGT
ORIGINAL: roundman
& that is good, because mine is cracked. My neighbor went through 19 trannys in his '89 GT including 1 C6.
Old Nov 28, 2004 | 12:57 PM
roundman's Avatar
roundman
19 trannys? you got to be kidding! what the heck was he doing to go through that many???
Old Nov 28, 2004 | 02:04 PM
mkspeed26's Avatar
mkspeed26
well, these are exactly the answers i was looking for, so thanks for that. now i am sure mine is a c4. i might do a little to it (manual valve body, higher stall) just so i can have some fun with it next summer.
Old Nov 28, 2004 | 03:19 PM
Jugador's Avatar
Jugador
remember, if you are running a stall you should have a good tranny cooler, especially if its street driven.
Old Nov 29, 2004 | 06:19 PM
mkspeed26's Avatar
mkspeed26
any suggestions for cheap but affective upgrades to a c4 tranny?
Old Nov 29, 2004 | 08:56 PM
619socalstang's Avatar
619socalstang
c-6 here in socal is really hard to get good parts for, c-4 is a good tranny and is not that much weaker than a c-6. if i was you i would go after market TCI or something close to that.
