sub frames and welding
Old Dec 2, 2004 | 01:48 AM
luckythirteen13's Avatar
luckythirteen13
Default sub frames and welding
ok, so im thinking of getting some sub frames and welding them in. the problem is, i usually only weld .25" mild steal. so im wondering how thick is the metal under the car? i dont want to punch right through it with the mig welder. last time i tried welding on a car body (which is really thin) i went right through and just made the hole bigger...and i had my welder set at its lowest and i was only welding in short bursts. long story short, what are the chances of welding right through the bottom of my car?
Old Dec 2, 2004 | 01:58 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: sub frames and welding
the parts where you'll be welding on the car are about 1/4 thick steel, same for the subframes so looks like your good
Old Dec 2, 2004 | 02:03 AM
primetime5.0's Avatar
primetime5.0
with my subframes it only said to mig weld it, is that what you were doing or stick welding?
Old Dec 2, 2004 | 02:45 PM
luckythirteen13
i was going to mig weld it
Old Dec 2, 2004 | 11:31 PM
roundman's Avatar
roundman
you need to worry more about setting the sound deadening materials underneath the carpets on fire than you do burning through the chassis when you weld on the connectors. I highly recommend you peel back the carpets and scrape up the rubber based sound deadening materials before you strike an arc as rubber burning will really stink up the inside of your Stang.
Old Dec 3, 2004 | 12:10 AM
luckythirteen13
what would you recomend as the easiest way to pull the carpet out of the way? i mean i want to pull up as little as possible.
Old Dec 3, 2004 | 12:42 PM
roundman's Avatar
roundman
you need to remove the rear seat bottom to get access back there and the carpet is loose so it peels up easy. to go the front, remove the seats, 4 bolts and one wire connector, and the lower door molding strip, several philips heads screws, and the carpet will peel up easy enough for you to get access to remove the sound deadening gunk. you can leave the carpet propped up with an empty beer can while you weld the subrames too.
Old Dec 3, 2004 | 10:41 PM
dc_mann8's Avatar
dc_mann8
ORIGINAL: roundman
i like how you think!
Old Dec 4, 2004 | 01:02 AM
luckythirteen13
will an empty bottle of Jack work?
Old Dec 4, 2004 | 10:44 AM
me alot fast than u's Avatar
me alot fast than u
I ♥ Acer
damn knew the 12 pak I drink would be benifial
