blow off valve help?!?
Old Dec 2, 2004 | 11:35 PM
91turbomustang's Avatar
91turbomustang
Default blow off valve help?!?
i just installed a blow off valve on a 2.3 turbo mustang but the air/fuel ratio gets messed up when boost is vented... the car dies everytime... what do i do? a bigger air flow sensor is what i'm told. but what is necessary for an 88 turbo coupe engine?
Old Dec 2, 2004 | 11:57 PM
Redline03GT's Avatar
Redline03GT
Default RE: blow off valve help?!?
Dyno tune the car at a performance shop that deals with turbos. You probably arent getting enough air or fuel into the mixture, or the psi is off significantly. There is also a chance that the blow off valve is too large for your application - ive heard of it before.
faststng902000's Avatar
faststng902000
is it vented back to the suction after the mass air or does it just blow off. we were told that on the vortech kit the mass air has allready read the air so when u lose air in the system( by blow off) it screws up your air fuel ratio.
Old Dec 3, 2004 | 12:21 AM
91turbomustang
it's blown off to atmosphere, i heard that if i get an air flow sensor that is 5mm bigger than my throttle body it should help the problem.
Old Dec 3, 2004 | 01:12 AM
JohnChule's Avatar
JohnChule
This happened to me when I had my VR4. An open loop BOV messes up the computer because it expects the air to go back in the system, but when it vents to the atmosphere the A/F ratio gets all F**ked up. To fix it you can get a closed loop BOV or get a AFC. All turbocharged cars are meant to have a closed loop BOV, when it vents into the air its just waste. I liked the sound of mine but it hurts performance.
faststng902000
we where told that it needs to vent back to the suck side after the m/a.
try www.turbomustangs.com a lot of turbo pep i think they could help.
Old Dec 3, 2004 | 01:45 AM
tyybo's Avatar
tyybo
What happens if you just stop venting and recirculate?
Old Dec 3, 2004 | 01:52 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
you need a bov or bypass on a fi car or its gonna buck and run like crap when the throttle slams shut. you can run a bov only if you've got a blow through maf and are venting before the maf
Old Dec 3, 2004 | 01:54 AM
nd_dsm's Avatar
nd_dsm
Right now it sounds like your venting. I know i had the EXACT same problem with my car while venting. Basically it was just throwing the maf off and what not and also making you run rich in between shifts, a simple way for me to fix that is dsmlink which gives me the option of No lift to shift setup, so i dont have to worry about running rich. Your best bet though to fix that problem is to simply recirculate, buy a piggyback tuning device or have the car dynotuned. The easiest way i think would be to recirculate the bov and then you should be fine.
Old Dec 3, 2004 | 01:57 AM
nd_dsm's Avatar
nd_dsm
ORIGINAL: mdvaldosta
Perhaps mustangs r completely different than the dsms, but when you say your venting before the maf with the blo through setup what do you mean? I know for us its a gm maf blow through setup and then the bov, so we would be venting AFTER the blow through.
Enlighten me a little bit, i could always use some more induction knowledge.
