Supercharged Cobra Question
Old Apr 20, 2007 | 09:16 PM
blown_cobra's Avatar
blown_cobra
Default Supercharged Cobra Question
I have a question about my car cutting out. I have a 97 Cobra with a Vortech V-1 supercharger,and once the cars boost starts to kick in into the higher rpm range (6000rpm) the car just starts cutting out real bad and falls on its face like it hit a rev limiter.I needsome advice from anyonethat knows what could cause this. Thanks
Old Apr 20, 2007 | 09:18 PM
FrostByte's Avatar
FrostByte
Default RE: Supercharged Cobra Question
Do you have a hand held tuner? The rev limit is prob set for 6100rpms. If you have a tuner, check it.
It tends to help us if you list your mods in your sig.
Old Apr 20, 2007 | 09:20 PM
blown_cobra
I dont believe its the rev limiter.When the car is parked i can give it gas all the way to 7200rpms with no problem, it only cuts out when the car has a load.
Old Apr 20, 2007 | 09:24 PM
blown_cobra
[hr]
97 Mustang Cobra 4.6L DOHC
Vortech V-1 Supercharger
Msd Coil
Msd Wires
Short throw shifter
Stock H-pipe w/o cats
Old Apr 21, 2007 | 12:34 AM
FrostByte's Avatar
FrostByte
ORIGINAL: blown_cobra
There areTWO rev limiter settings. One is for neutral & the other is for in gear. The one for "in gear" is the prob. I had my tuner hooked up yesterday & noticed the 2 settings. Even if they are different tuners it is prob same.
Good luck, i just hope is some thing as simple as that.
Old Apr 26, 2007 | 03:26 AM
97WHITEVENOM's Avatar
97WHITEVENOM
I am interested to know if you ever found the problem?
Old Apr 26, 2007 | 04:58 AM
NeoTokyo's Avatar
NeoTokyo
Ya my truck was the same way, feels like something really bad is going on with the engine, its just the limiter. My truck would actually flash the check engine light every once in a while cause it was going a lot faster then it was intended for, 140ish ^_^ ehermmmm On a closed track of course
Old Apr 26, 2007 | 07:18 PM
blown_cobra
I changed my spark plugs and if fixed the problem
Nov 10, 2015 11:39 AM
Luke9222
Oct 22, 2015 11:55 PM
Sparks_88
Sep 8, 2015 01:06 PM
Sep 3, 2015 07:14 PM
