camshaft
Old Apr 22, 2007 | 09:38 PM
confusedp66's Avatar
confusedp66
Default camshaft
i have a 84 5.0 mustang,does anyone know if it has a roller cam or ? and if not can you put a roller cam in it if its not?
Old Apr 23, 2007 | 12:31 AM
67mustang302's Avatar
67mustang302
Default RE: camshaft
I do not believe so. Yes, you can put a roller cam in a non roller engine by purchasing a roller conversion kit from Comp/Crane etc that has a roller cam/lifters. It has paired lifters with a link bar, and you have to make sure you get the right base circle so it fits in the cam bearings. If you call someone like Comp they can help you determine what part # you need. These setups are also very expensive from what I understand, the lifters are pricey.
Old Apr 23, 2007 | 12:32 AM
67mustang302
Also the heads have to be removed to use the roller conversion lifters, they're too tall to fit under the head into the lifter bore
Old Apr 23, 2007 | 02:20 AM
confusedp66
ty for your help
Old Apr 23, 2007 | 02:30 AM
67mustang302
Errr, correction, makesure the cam has the right base circle and that the cam journals are the same size(I dunno if they're different, but again, the cam companies know this stuff). As far as the base circle it might require different length pushrods as well(It's almost a garuntee it will). That's why the companies have kits
djbigskrilla
Sep 20, 2022 01:04 AM
NYstang
Sep 30, 2015 09:56 PM
uberstang1
Sep 20, 2015 06:42 PM
2003 4.75l
14
Aug 29, 2015 02:58 AM
Redneck1465
Aug 8, 2015 10:39 PM
