vert help please
Old Dec 8, 2004 | 09:51 PM
ss4ever's Avatar
ss4ever
Default vert help please
94 vert, top doesn't work. Was told that they are hydrolic, is that true? If so how would a person go about filling it back up and what kind of fluid does it take?
Thanks
Randy
Old Dec 9, 2004 | 03:05 PM
ss4ever's Avatar
ss4ever
Default RE: vert help please
Anyone?
Old Dec 9, 2004 | 05:26 PM
ryan1994mustang's Avatar
ryan1994mustang
i think that your best way to go on this one is to take it to a ford dealership, or someone who specializes in vert tops and let them check you out. Im not positive if they are hydraulic or not, but i replaced my top a couple weeks ago and dont remember seeing any hydraulic cylinders anywhere. i know that they have motors, and i dont know if hydraulic systems have motors or if they just hook to a power source. that is why i say go somewhere where they actually know what they are doing.
Old Dec 9, 2004 | 06:15 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
yea if it is an automatic top, it has a motor, but see a specialist about this kind of thing.
Old Dec 9, 2004 | 10:40 PM
ss4ever's Avatar
ss4ever
OK, thanks. I have yet to have a look at the car in the light so I don't know what is up with it.
Thanks
Old Dec 13, 2004 | 06:32 PM
90vert5.0's Avatar
90vert5.0
I have a '90 convertible. Mine has hydraulic cylinders that actuate the top. For me, in order to access the motor, I go into the trunk and take out the panel at the back of the trunk and it is sitting right there. Might as well check and see if it is the same. If you find the motor, you should be able to tell if it has lines for hydraulic fluid going to it.
Mine stopped working a while back. It wouldnt even try to move. So i just took the motor apart a bit and put it back together and its been working for about a year now. I think there was just some sand in there.
Old Dec 13, 2004 | 06:49 PM
ss4ever's Avatar
ss4ever
Hey, thanks for the helpful reply, more that have been getting. I will have alook at it sometime.
Old Dec 13, 2004 | 11:04 PM
Mustangous's Avatar
Mustangous
Do you hear anything when you try to activate the top up or down? If you hear nothing first try simple things. like a fuse. Also there is a relay for the motor. check if it is getting power when you press the switch up/down. If you dont hear a whine from the motor then dont bother checking if the hydrolic fluid is full, if it is hydrolic which it should be....
goodluck!!
Old Dec 14, 2004 | 12:00 AM
ss4ever's Avatar
ss4ever
You can hear the motor running but nothing happens.
robcy
Suspension
Oct 27, 2015 11:14 PM
MasterLanMan
Sep 26, 2015 10:03 AM
12bigredstang
Sep 24, 2015 10:43 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
ShaneB26154
Aug 28, 2015 04:47 PM
