What's the most fuel efficient way to accelerate?
Old May 4, 2007 | 11:17 PM
JibStyle's Avatar
JibStyle
Default What's the most fuel efficient way to accelerate?
If i'm cruising in a higher gear such as 5th, but at a low RPM, if i want to speed up at a moderate pace am i gonna get better milage out of flooring it in 5th, or dropping it down a gear or two and not stepping on the throttle so hard? I figure that by going WOT in 5th, that means the intake is drawing in a lot of air, which means a lot of fuel, even if the cylinders are firing less (low rpms). But in a lower gear and not with WOT, its not taking in as much air/fuel due to only partial throttle, but it is also at a higher rpm.
So basically, will i get better gas milage while accelerating by going WOT but lower rpms, or partial throttle and high rpms, or is there some sort of balance i should find?
Old May 4, 2007 | 11:54 PM
Donnie's GTS's Avatar
Donnie's GTS
Default RE: What's the most fuel efficient way to accelerate?
1-3-5 shift at 2000-2500 rpms.
Old May 5, 2007 | 12:10 AM
hammeron's Avatar
hammeron
a physics major could actually answer this
question with confidance.....i'm just a blue
collar slob, so i'm not even gonna try and guess...
Old May 5, 2007 | 12:34 AM
roush17's Avatar
roush17
I would think gradually increasing the speed in 5th would be the most fuel efficient for the reason that you are not WOT and are still at a lower rpm.
Old May 5, 2007 | 12:47 AM
GreyStang's Avatar
GreyStang
A good question. But really, the whole process of accelerating in the way you describe will be completed in around 5-10 seconds, and either method of acceleration won't make a thimble full of fuel difference
Old May 5, 2007 | 11:31 AM
Chopper's Avatar
Chopper
One high speed run through the gears will drop fuel mileage by one MPG per tankfull.
I can get 32 mpg by shifting at 1500 rpm and driving 55 mph.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
