charging problems
Old May 11, 2007 | 10:32 PM
PONY GUY's Avatar
PONY GUY
Default charging problems
Ihave a eletcric fan holley fuel pump and eletric water pump , My battery is a optima red top and my alt also tested good awell ( took battery and alt to advance to get them tested .. When i go to start my car my volt meter got from 12v down to 9v but then fires and wont go past 12v at idel or when a raise the rpm's to 2500 rpm's . I charge my battery up and let it sit then go back and check it with a multi meter and I can actualy watch it drop voltage as it sits un hooked in the car . so I figure my battery is bad all new cable and everything my alt is a gm 1 wire on 65- 70 amp , I gona up grade it to a 95 amp becuase of all the draw my fan , water pump , & fuel pum draw, Is it possible my battery is shot even though they test it and it comes back ok ????
I alos have under drives pulley on the crank and stock pulley on my alt I was gona try to get a sock pulley for the crank since I got the car with the underdrive pulley and I dont belive the help a hole lot
for street aplication .
I hope someone can help me and thanks in advance
Old May 12, 2007 | 12:22 AM
PONY GUY's Avatar
PONY GUY
Default RE: charging problems
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 12, 2007 | 06:02 AM
02 GT's Avatar
02 GT
your guage on the dashcould be bad,
does it drive allright?
Old May 12, 2007 | 10:52 AM
PONY GUY's Avatar
PONY GUY
I have a autometer and it reads the same as th one in the dash and they also read the same thing that my multi meter says
Old May 12, 2007 | 07:45 PM
PONY GUY's Avatar
PONY GUY
well I got a new red top today and unpuged my eletric fan whichg is on all the time . my car went to 14.5v at idle so I just used a toggle switch that was on my console but wetn to nothing so I switch it on and off when I need . the swtich will work till my 108amp alt comes on monday Ill probally set up teh fan to be tempeture controled soon
Old May 12, 2007 | 09:59 PM
02 GT's Avatar
02 GT
sounds like you got things taken care of then
Old May 13, 2007 | 07:40 PM
PONY GUY's Avatar
PONY GUY
yeah but my mini high tourqe starter craped out on me so I gotta pull out my p/s header and pull it out and geta ford racin starter
Old May 13, 2007 | 08:56 PM
02 GT's Avatar
02 GT
sounds fun [8D]
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
