MORE electri problems
Old Dec 17, 2004 | 10:08 PM
TRL12087's Avatar
TRL12087
Default MORE electri problems
Lately ive been having electric problems with my 86 gt. At first the problem was only in my wipers, radio, and gauges, but now it is to the point that i can not even start my car. The car has power.. like the interior lights go on when i open the door but the only way to have power running through my ignition i have to push up on the steering wheel and pull down on the key ignition.. and as soon as i let go the car dies and im stuck again. Im assuming its something in the column but i have no clue where to start. Any help would be great.
Old Dec 17, 2004 | 11:09 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: MORE electri problems
could be the ignition switch. you know when you turn the key forward to crank the motor? well our aerostar has problems with the switch. some times when you crank the motor the switch doesnt pop back all the way and non of the electrical things will work
...just a thought
Old Dec 18, 2004 | 12:21 AM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
eyah. Do you have tilt??? May have broken wires.
Old Dec 18, 2004 | 07:01 PM
TRL12087's Avatar
TRL12087
yea i do have tilt and thats kind of what i though when i said its probably in the column but what can be done to fix it or at least see whats wrong exactly
Old Dec 18, 2004 | 07:46 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
lol. Remove youre plastics around youre column. Thats all. Then see if you got broken wires. If so fix that... Its pretty simple.
Old Dec 18, 2004 | 09:23 PM
TRL12087's Avatar
TRL12087
well ive already done that and i didnt see any broken wires or anything but there is a white plastic piece on the right side of the column that is loose... i pushed up on it and it did work but as soon as i let go it shut off again... am i supposed to just zip tie it up there or what cuz i didnt really see a way to take it off unless i REALLY pull apart the rest of the column... and i think i have to pull off the steering and sh*t for that
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
