Friction Point Adjustment
Old May 16, 2007 | 05:34 AM
josmoe5000's Avatar
josmoe5000
Default Friction Point Adjustment
I just purchased a 2000 Mustang GT 5 speed. The friction point is high like 3/4 out on the clutch. I would prefer the friction point to be between 1/4 and 1/2 way out. Is there a way to adjust the friction point? Is there a reason why I should not adjust it?
Old May 16, 2007 | 06:40 AM
TheMustangLoveR's Avatar
TheMustangLoveR
Default RE: Friction Point Adjustment
The car comes stock with a self-adjusting plastic quadrant. To make sure it is set right, put your foot behind the pedal and pull outward toward you with some pressure. Then push the pedal to the floor. That should adjust it, although it may make no difference. From the factory there is no user-adjustability to the clutch, unless an adjustable clutch cable was installed, or/and a firewall adjuster was installed. To determine if you have a firewall adjuster, you simply look in your engine bay, at the firewall on your driver side and you will see where the clutch cable goes through the firewall. If there is a metal **** there, you have a firewall adjuster. If not, then that adjustability is out, so next you can check if you have an adjustable clutch cable. Simply jack up the car and get under the transmission. You will see an inspection cover that is held on by one bolt. Remove this cover and you will see the clutch cable connected to the clutch fork. If you seethatthe cable is threaded and has two nuts on it where itconnects to the clutch fork, then it is adjustable. Else, you have no adjustability.
You can check these things and go from there. Hope that made sense.
Old May 16, 2007 | 07:22 AM
josmoe5000's Avatar
josmoe5000
If Iadjusting the stock clutch by pulling it up then pushing it all the way in is it possible that it would make it worse or even not driveable?
Old May 16, 2007 | 06:24 PM
josmoe5000's Avatar
josmoe5000
I tried pulling the clutch pedal back to release the adjusting mechanism but it won't move back any. Is there something that I am missing on how to do this?
Old May 16, 2007 | 06:49 PM
josmoe5000's Avatar
josmoe5000
I found the problem is that the quadrant is already adjusted as far as it will go. What needs to be done/replaced at this point? Any advice would be greatly appreciated.
cr620
Oct 3, 2022 10:18 PM
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
