destroyed a piston how expensive to fix
Old Dec 21, 2004 | 01:29 PM
Acer2428's Avatar
Acer2428
Site Mod
Default RE: destroyed a piston how expensive to fix
Why has no one suggested a 5.1L stroker kit? Will cost you $1900 for the kit + install...
Old Dec 21, 2004 | 05:18 PM
bobby's Avatar
bobby
dude, that tap u heard was cuased bu to far advanced timing, not a piston!
Old Dec 21, 2004 | 06:24 PM
Jugador's Avatar
Jugador
or the timing caused the piston to break and the piston was making the noise...
and acer, that might be a good idea, but who knows if the block is fuxxored (or does the 5.1 need a .030 overbore anyway)
Old Dec 21, 2004 | 11:49 PM
black00gt's Avatar
black00gt
that sucks, the dealership will rape you if you take it there to get fixed.
Old Dec 22, 2004 | 04:55 PM
Fallstar01's Avatar
Fallstar01
Karkraft engines
There are alot of cool choices on there for less than $4000.
Old Dec 22, 2004 | 09:02 PM
tinman's Avatar
tinman
Yep, I think that I would stay away from Ford dealer for a new engine too. Remember, you get what you pay for in the end. Also, you can bet that the cylinder that the piston broke in is f--ked up too.
Old Dec 23, 2004 | 11:51 AM
roundman's Avatar
roundman
After thinking about this some more, I can't really see how 2 degrees timing advance could "break a piston" unless you used low octane gas and ignored the sounds of pinging in the engine under load. I would take the car to another mechanic and get a second opinion without telling him that you already had someone else diagnose it so his opinion is not biased by the first guy's. I definitely wouldn't change engines without a second opinion and the exact reasons why they say you have a broken piston.
Old Dec 24, 2004 | 04:01 PM
me alot fast than u's Avatar
me alot fast than u
I ♥ Acer
if you have a broken piston it wouldn't run long as it will crumble.....the 01 as well as many other have the knock sensor most chips don't disable it....as for a new engine why not a low mileage 5.4 out of a truck or navitgator? now with timing a remote thing to happen is a small hole in the piston which would be a pop sound....
Old Dec 24, 2004 | 11:25 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
my mom has a 95 lexus, cam locked up and wouldnt turn, used lexus v8 with 70k miles on it was 1500 dollars, lexus engines are expensive though, so if comes to buying another engine, ask some local small shops and stuff, not dealers.
Old Dec 25, 2004 | 12:39 PM
me alot fast than u
I ♥ Acer
are we sure you not hearing piston slap that was a common problem with the all mighty 4.6
