Door lock help
Old May 21, 2007 | 09:58 PM
damagd's Avatar
damagd
Default Door lock help
My door locks stopped working years ago on my 89 GT so I recently purchased new door lock actuators -- I just hooked them up and I get nothing -- The power windows work fine -- I don't see a fuse for them -- Any suggestions? Can I check for power somehow? Thanks
Old May 22, 2007 | 08:55 AM
corvetteguy's Avatar
corvetteguy
Default RE: Door lock help
You should be able to take off
the driver's door panel or maybe
just the door pull to get to the
lock switch. Use a meter to
see the voltage.
I disconnected the pass lock switch
and all locks now do not work.
Since your orriginal problem was most
likely not the actuators you may have
changed things so that it may never
work. I would re hook up old ones and
check. If no power, there is a fuse.
Old May 22, 2007 | 06:39 PM
damagd's Avatar
damagd
Where would the fuse for it be? -- I don't see one for it in the fuse panel under the dash
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
