Need Help no rear brakes!!!
Old May 23, 2007 | 11:37 AM
DanDman1's Avatar
DanDman1
Default Need Help no rear brakes!!!
To make a long story short I have a 03 with disc brakes on the rear. The drivers side rear caliper had a major leak to where it drained the master cylinder fairly quick and now after replacing the caliper and fluid I tried to bleed the system and when I pump up the brakes to bleed the rear there is no fluid going to the rear brakes. I was told that there is some sort of safety valve built in the line of the ABS system that has to be reset after a major fluid loss to allow the fluid to get back to the rear calipers. My question is if there is such a valve or safety device where is it located and how do you reset it?
Thanks
Dan
Old May 28, 2007 | 02:28 PM
DanDman1's Avatar
DanDman1
Default RE: Need Help no rear brakes!!!
Anybody?
Old May 28, 2007 | 02:54 PM
351W THUNDER's Avatar
351W THUNDER
if ur front brakes work then its not it. u prolly have **** in the line
mtgldr
Feb 3, 2024 09:00 PM
Galactic
Apr 29, 2019 02:56 PM
musnicki
Sep 23, 2015 07:11 AM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 1, 2015 08:16 PM
