AODE Problem
Old May 23, 2007 | 12:58 PM
oldgoat's Avatar
oldgoat
Default AODE Problem
Got an AODE tranny that has a clunk in it when you accelerate from low speed. Sounds like it is from the back of the tranny. New U-Joints. Feels like the shaft going in has a lot of play. My son says the rpm's seem to jump real high when he gets on it going around a corner. Any ideas?
Old May 23, 2007 | 01:54 PM
ackuric's Avatar
ackuric
Default RE: AODE Problem
i have the same issue, idk. if i let it coast down hill with no throttle the tranny has a little clunk going from 1-2 or 2-3, not consistent either. hopefully someone can shed some light. I've read somewhere abour the planetary gear set having sometype of spring and that can fail/break and allow the gearset to hit the tranny case. not sure though.
Old May 23, 2007 | 01:56 PM
GreyStang's Avatar
GreyStang
Check the tranny mounts make sure they're OK.. I can't imagine why the engine would rev high going around a corner though..?
Old May 24, 2007 | 10:12 AM
oldgoat's Avatar
oldgoat
Is it maybe revving due to something slipping in the traction lock? Seems to do it around corners. Rear end is getting rebuilt on Monday and 4:10's put in. I guess we'll see.
Tranny mounts are solid. It sure seems likethe clunkis from some slop in the tranny.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
