5.0L oil pan?
Old Jun 4, 2007 | 04:45 AM
CW's Avatar
CW
Default 5.0L oil pan?
Is there a difference in oil pans from a fox body to any other car such as a crown vic, T-bird, etc?
Also pick up tube?
Old Jun 4, 2007 | 08:05 PM
CW's Avatar
CW
Default RE: 5.0L oil pan?
Hello?
Old Jun 4, 2007 | 08:07 PM
andrewmp6's Avatar
andrewmp6
youll have to crawl under then and see some cars use a front sump some use a rear it all depends on the car its in
Old Jun 4, 2007 | 08:23 PM
CW's Avatar
CW
I am swapping from a v6. What pan does the fox body normally use?
Old Jun 4, 2007 | 08:30 PM
andrewmp6's Avatar
andrewmp6
its a rear sump for the fox body some good info you might want to read http://www.jason.fletcher.net/tech/v8/v8.htm
Old Jun 5, 2007 | 03:53 AM
CW's Avatar
CW
Thanks ill read that. It should help. Im used to building chevs so this is all new to me.
Old Jun 5, 2007 | 09:29 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Actually, the Fox uses a double hump pan to get the capacity. Not all rear sumps will work.
Old Jun 5, 2007 | 09:44 PM
CW's Avatar
CW
So its probably best to find a proper fox body pan?
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
