important question
Old Jun 4, 2007 | 11:17 PM
lebo89stang's Avatar
lebo89stang
Default important question
whats up guys i am new to this forum but i hear you guys are the best. my question is i just bought a 1989 gt 5.0 ho and it is really jerky when it is cold and when it warms up when you floor it, it bogs out but if you accelerate with 3/4 throttle it pulls hard. i have cleaned my, maf, iac, and egr and tb and it still does it. i adjusted the timing and it still does it. my question is what is the sensor on top of the coolant overflow jug? mine has no wires going to it. also i am missing a header bolt but i can not hear or smell any exhaust leaking from it. please help it you can thank you brian.
Old Jun 4, 2007 | 11:18 PM
lebo89stang
Default RE: important question
it has a 5-speed trans just in case it makes a diffrence.
Old Jun 5, 2007 | 02:01 AM
ctgreddy's Avatar
ctgreddy
i think the sensor on the coolant tank is just to see if the coolant level is low. did you try doing an ignition tune up? that couldnt hurt any.
Old Jun 5, 2007 | 02:04 AM
945LSTANG's Avatar
945LSTANG
is the check engine light on?
Old Jun 5, 2007 | 09:11 AM
lebo89stang
no there is no check engine light and i just did a tune up that was the first thing i did. any other ideas? i cant figuere it out.
Old Jun 5, 2007 | 12:09 PM
TwotoneVert's Avatar
TwotoneVert
If the ignition is is in good shape, plugs, wires, cap, rotor, etc. Then it could be fuel related. Check the fuel filter and pump, check for good pressure. Have you checked TPS voltage?
Old Jun 5, 2007 | 02:27 PM
945LSTANG's Avatar
945LSTANG
+1
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
