Codes on fuses
Old Jun 8, 2007 | 02:14 PM
MustangSally99's Avatar
MustangSally99
Default Codes on fuses
I'm still trying to locate the parasitic drain on my '99 GT.
What do these two acronyms stand for?
PCM
GEM
And I know that the fuse showing the drain is F, fuse position I/P, 40 amps, and circuits protected are: Instrument cluster and PCM.
How do I know which fuses under the dash are connected to this fuse under the hood? I want to start pulling them to see what happens.
Any help is greatly appreciated. I refuse to pay $90/hour for some grease monkey to do the same thing that this blonde monkey can do
Old Jun 11, 2007 | 03:44 PM
MustangSally99
Default RE: Codes on fuses
PCM is the power control module, which is the computer.
Still not sure what the GEM is.
I still don't know how the fuses under the dash are connected to the fuses under the hood. I'll start pulling fuses under the dash and test.
If anyone out there in Mustang Land has ever had a problem with the PCM, please respond. I'd like to know if there is a relay and if it could be drawing extra current when the battery is reconnected.
Old Jun 11, 2007 | 04:24 PM
Gary H's Avatar
Gary H
This is for an explorer, but it might help. Read the last reply
http://en.allexperts.com/q/Ford-Repa...explorer-1.htm
Old Jun 14, 2007 | 01:13 PM
MustangSally99
Thanks again Gary!
Too bad the guy doesn't answer electrical questions*S*
Old Jun 14, 2007 | 04:37 PM
Gary H's Avatar
Gary H
Just curious, but did you try and pull any codes from the computer? Might tell you something. Not up on computer controlled cars, but you can usually get it done for free at most parts stores..
Old Jun 15, 2007 | 03:46 PM
MustangSally99
I am doing the instrument cluster diagnostics, and so far the numbers for the voltage on the battery have gone from 148 to 144 to 147 over a period of 5 days, which is in the normal range. Inconsistent to say the least.
And there are no DCT warnings, everything else checks out okay.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
