V8 Conversion Questions
Old Jun 10, 2007 | 05:41 PM
SuperItalian's Avatar
SuperItalian
Default V8 Conversion Questions
Ok, so I have a 2004 V6 (my first mistake hehe) and I want to convert it to a V8 so I can make some nice power gains from it. There simply isnt enough in a 6er for me.
Anyway, I figure to convert from a V6 to a V8 I need to get an engine, transmission, driveshaft, and rear end. I am not mod savvy, and I know that this cant be all I need. Please give me some pointers and info on how to make this a clean transition. Here is what I found on Ebay to get me started as far as ideas are concerned. Let me know if I have the right idea. Thanks in advance for any info and advice.
Engine: http://cgi.ebay.com/ebaymotors/1999-...QQcmdZViewItem
Transmission: http://cgi.ebay.com/ebaymotors/T56-T...QQcmdZViewItem
Rear End and Driveshaft: http://cgi.ebay.com/ebaymotors/MUSTA...QQcmdZViewItem
I dont know what gears come with the Cobra rear end, but I was planning on upgrading it to 3.73 gears.
Old Jun 11, 2007 | 01:30 PM
wgdt21's Avatar
wgdt21
Default RE: V8 Conversion Questions
just sell it and buy a V8. It will save you alot of time and hassell
Old Jun 11, 2007 | 02:19 PM
onegreedy's Avatar
onegreedy
THATS ONLY A START.....
you need the entire wiring harness from the car to match the engine and trans , the rear end is not complete so you would need the rest, better off getting a complete rear end at 1 time , you need the fuel system ( tank fuel pump and fuel lines) computer and other various electronic parts you will need the dash cluster for a gt or cobra and you will need it all programmed
not including the main components you listed you have $3000.00 in parts needed
i did this with a 1999 gtengine and trans i had 6200.00 total including engine and trans , but thats becuse i got ia deal 1750.00
all the info 1997 mustang v6 conv auto to 1999 mustang gt conv auto
First I will list the parts that were required to do this swap
Major components
Engine 1999 4.6 sohc 46xxx miles
Transmission auto tranny out of a 1999 gt
Rear end 1999 cobra irs
wiring
Engine wiring harness
Ecu wiring harness
Body wiring harness
Dash wiring harness( has fuse box connected)
Door wiring harness
Under hood wiring harness (has under hood fuse box connected and ccr)
Center console wiring harness
Turn signal harness
Fuel system
Gas tank
Gas tank filler neck
Gas lines from engine to tank
Charcoal canister
Air pump on pas fender
Various fuel lines and hoses
Fpr
Components needed
Gem module( general control module)
Constant control relay module
Ecu
Fuel relay ( trunk)
Srs relay and srsair bags
Abs compressor
Radiator
Overflow tank
Hydramatic brake system( mounting holes are different size needed to redrill out)
Power steering Lines
brake booster
master cylinder
various relays
I did not use it but it is easier to just get a dif steering collum( because of pats and turn signal switch)
Turn signal switch
Gauge cluster
Exhaust system
Cruise control module and cable
Throttle cable
Air filter set up
4.6 exhaust
Door latches
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
