T5 Rebuild
Old Jun 14, 2007 | 09:02 PM
dadoordude's Avatar
dadoordude
Default T5 Rebuild
Just installed a rebuilt T5, my son started the car before I got home from work yesterday to show his friend how loud the open headers were,Ihad not fill the case yet,he told me this when I got home.
I filled the case and started the car, there is now a clicking / gear noise ? the noise only speeds up under RPM not while in any gear, ran it through all five gears under idle and under throttle,input shaft bearing bad ?
Old Jun 14, 2007 | 10:52 PM
945LSTANG's Avatar
945LSTANG
Default RE: T5 Rebuild
does it make noise with the clutch depressed? u say it only happens in neutral??
Old Jun 15, 2007 | 03:16 PM
dadoordude's Avatar
dadoordude
Yes it does but not as loud,as stated ran through all 5 gears with clutchengaged and on jack stands,noise did not increase unless RPM was increased, idle is set at 700 rpm but the noise is not 700 times a minute ? you thinking it might be in the clutch ?
Thanks
Old Jun 17, 2007 | 10:19 PM
dadoordude's Avatar
dadoordude
Any idea's anyone or where to start looking ? will start tear down in two weeks, any help would be greatly appreciated, anyone know who makes a clutch cable for this car 66 Ranchero, none of the 65-67 mustang or falcon ones will work, thanks all.
Old Jun 17, 2007 | 11:58 PM
945LSTANG's Avatar
945LSTANG
not the clutch. my guess is the front bearing. you will have to tear it down to find out for sure. dont buy anything until you know exactly what the problem is.
Old Jun 18, 2007 | 12:13 PM
dadoordude's Avatar
dadoordude
Thanks, I will let you know what I find.
Old Jul 16, 2007 | 04:09 PM
dadoordude's Avatar
dadoordude
Found problem was in pressure plate hitting bellhousing on drivers side,bell was made for a 10" clutch, installed a 10.5 as told from seller,good thing I am a retired machinist, machined inside of bell to clear bigger clutch set, no noise at all now.
Old Aug 7, 2007 | 02:36 PM
dadoordude's Avatar
dadoordude
Finally got the beast on the road sunday evening,had a lot of fun with machining and making the clutch cable work in this 66' Ranchero, nothing like a mustang set up,WOW what a difference with the T-5 instead of C-4 / stall,totally smokes em through 1st & 2nd with 325 posi, gotta get some street slicks to save rubber, did a freeway run let off after hitting 140+ got a little squirly but still had more motor left.
Dathan
Oct 5, 2015 05:52 AM
Drastang
Sep 30, 2015 03:48 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
8lug
Sep 21, 2015 01:33 PM
