CLUTCH REPLACEMENT
Old Jun 15, 2007 | 12:59 PM
mjg's Avatar
mjg
Default CLUTCH REPLACEMENT
I recently had my clutch replaced.
My pedal is about 2"higher thanthe brake pedal.
When the clutch is new, isn't the pedal height
supposed to be same as the brake pedal?
Also, when I shift into 5th gear at 70-75mph at
approx. 3000rpm, the gears grind.
This makes me think the clutch was not adjusted
properly, when installed.
Is this correct?
eta: 2004 Mustang, V6, 3.9l, grey pony
Old Jun 20, 2007 | 02:54 PM
mjg's Avatar
mjg
Default RE: CLUTCH REPLACEMENT
bump
no clutch experts in here?
where should I go?
I need some help.
Seriously.
Old Jun 20, 2007 | 04:37 PM
945LSTANG's Avatar
945LSTANG
sounds fine to me....if your clutch wasnt adjusted properly it would grind when you shift into every gear, and not just 5th.
Old Jun 21, 2007 | 11:05 PM
JESTER01GT's Avatar
JESTER01GT
If it is just grinding in 5th it sounds more like a synchro problem to me. I am no trans expert by any means but I would start there.
Old Jun 22, 2007 | 02:16 PM
mjg's Avatar
mjg
There is a lot of fluid on the drive shaft and around the (transmission) rear seal.
Is it common practice to pull the output shaft from the tranny rather than disconnect
the drive shaft at the u-joint? If the fluid that was spilled/lost is not replaced and the
rear seal is leaking, could that cause this (grind) problem?
I guess I will change the seal and fluid tomorrow.
My shifter is squeaking too for some reason.
5.0muscle
Jan 11, 2016 01:17 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Emblazoned
Sep 3, 2015 10:45 PM
