need help with ac clutch
Old Jun 15, 2007 | 05:58 PM
Eduardo's Avatar
Eduardo
Default need help with ac clutch
So last week I took off my ac compressor because of a broken bolt that was stuck in it. Fixed it but now the new bolt that I put in it wont stay tight. I made sure it was tight when I put it back on but it keeps coming loose. Whats going on with it. Is there anything I can put on it to make it stay on there?
Old Jun 15, 2007 | 06:10 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: need help with ac clutch
ORIGINAL: Eduardo
Was the hole retapped when you took the broken bolt out? If it was and you used the same size bolt as what was in there to replace it, there's problem. You need to go a size up. Whatever that may be. If the bolt is the identical size, use a medium strength loctite to keep it in place.
Old Jun 15, 2007 | 06:16 PM
Eduardo's Avatar
Eduardo
No the hole was not tapped. I just drilled the middle of the broken bolt out and the drill bit never touched the side.
Old Jun 16, 2007 | 05:56 PM
Chopper's Avatar
Chopper
Blue Loctite= Removable but tight.
Red Loctite= semi-permanent.
Green Loctite= Forever.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
