Taking off in first
Old Jun 17, 2007 | 07:44 PM
Movieman33's Avatar
Movieman33
Default Taking off in first
I am the proud owner of a 4.6L v8 2002 mustang gt, but I have one issue with it. When I want to take off after at a light, i give it like 2 rpms in first and the car feels so sluggish and slow. Do I give it more rpms and when do I put it into 2nd?
Old Jun 17, 2007 | 08:11 PM
hotrod7687's Avatar
hotrod7687
Default RE: Taking off in first
Im assuming you have a manual. The tachometer measures RPM's by the thousands. Whatever number it is on, like 2, is actually 2000 rpm.
Sounds to me like this is your first manual.You might bebogging it a little on the takeoff. Are the rpm's staying at 2000 when you let off the clutch or are they falling below that when you take off? Next time try giving it more throttle as you let off the clutch. It just takes practice to get a good launch. If you are trying to run someone, or want to take off faster, try launching at around 3k rpm. When i shift into antoher gear depends on what im doing. If im just driving around town normally, i shift from one gear to another at 2500-3000 rpm. If im at the track racing, i shift around 6k rpm.
Unfortunately, the 4.6 isnt known for low end torque, so it takes getting it up in the rpm range to start making power. When I had my 99 gt, it really didnt start to pull until 3k or higher. Mine would get up there pretty quik since i had 3.73 gears in the rear but still wasnt very impressive until then.
Old Jun 17, 2007 | 11:08 PM
cottoncandymustang's Avatar
cottoncandymustang
for mine i push in the clutch rev it to about 3 grand . soon as the lights on the tree go green i let off the clutch then put it to the floor and no sluggish probs at all
Old Jun 17, 2007 | 11:53 PM
945LSTANG's Avatar
945LSTANG
u launch a 5.0 at 3000 rpm?! way too high for street driving. should be more like 2000 rpm. sounds like u pop the clutch = short clutch life.
Old Jun 18, 2007 | 10:13 AM
Chopper's Avatar
Chopper
On flat pavement you should be able to take off without giving the car any gas at all.I wouldn't try that in traffic but if you let the clutch out slowly and smoothly enough,it can be done.
In traffic,even with stock gears,you shouldn't have to rev the engine past 1,500 rpm to take off.That is a valid shift point for normal driving also.Going any higher just makes noise and wastes gas.This is for "in town" driving,getting onto a congested interstate is dangerous enough without poking around and making the problem worse.FLOOR IT!!!! WooooHoooo.
Old Jun 19, 2007 | 02:17 AM
capri_83's Avatar
capri_83
3000RPM not = short clucth life....= short tire life.....but really fun with 4:10s
Old Jun 19, 2007 | 03:38 PM
cottoncandymustang
yea brother ive been doing that for almost 2-3 years never had any problems with the trans or clutch tire life.. heh heh ... im not going to even talk about that haha
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
