Car Shudder/Vibration
Old Jun 20, 2007 | 04:12 AM
salcido16's Avatar
salcido16
Default RE: Car Shudder/Vibration
i had the same problem...for me it was a loose driveshaft...my drive shaft would vibrate more noticable when i would shift from 1st to second..
Old Jun 20, 2007 | 11:09 AM
theponyfactor's Avatar
theponyfactor
well i would think that when i had the u-joint replaced, that would have been noticed and fixed...
Old Jun 20, 2007 | 04:48 PM
945LSTANG's Avatar
945LSTANG
there is more than 1 u-joint...check the old one. and also check the runout on the driveshaft, you never know. did any balance weights fall off ofthe driveshaft?
Old Jun 20, 2007 | 05:09 PM
theponyfactor
i had the one u-joint replaced at a local shop by guys who have been very good to me in the past. He said the other u-joint was fine. I would assume he would have checked everything else out too. When I told him the shake was still happening he told me to come pick him up and take him for a drive so he can try and figure it out. I was hoping to fix it myself though...
Old Jun 20, 2007 | 05:16 PM
P Zero's Avatar
P Zero
The shake can be from the driveshaft being out of phase. Meaning it wasnt installed in the same position it was removed. Also, the driveshaft could have loosend up if he didnt loctite it when re-installing.
-P.
Old Jun 20, 2007 | 06:41 PM
theponyfactor
ORIGINAL: P Zero
-P.
well this was the first time the driveshaft had been removed, and it was happening before this....so i dont think it's from re-installing. easy way to fix the driveshaft? or shouldi just take it in...
thanks for all the help.
Old Jun 20, 2007 | 10:01 PM
945LSTANG's Avatar
945LSTANG
id take it back in.
Old Jun 21, 2007 | 09:42 PM
theponyfactor
well i took the guy for a drive and he said he thinks its ignition. i replaced the plug wires (didnt get plugs like an idiot) and that didnt fix it. to me i just doesnt seem like its coming from the engine...UGH!
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
