will someone ease my mind
Old Jun 26, 2007 | 01:14 PM
2broke2gofast's Avatar
2broke2gofast
Default will someone ease my mind
Got a 95 GT with AFR heads. Even before the heads were installed the car reached 220* before the cooling fan kicks on. Replaced the cooling fan switch, same thing. Is this the correct running temp? It generally runs around 200 but quickly gets up to about 217 at idle then the fan will come on. Am I ok? Thanks
Old Jun 26, 2007 | 01:33 PM
Gary H's Avatar
Gary H
Default RE: will someone ease my mind
I think the stock thermostat is 195*, so you might get one that opens sooner. Alum. heads will cause the car to run a little hotter, thye transfer heat faster. What about the fan temp sensor, too?
Old Jun 26, 2007 | 01:47 PM
2broke2gofast
Got a 180 thermostat in it, and have replaced the the sensor. It has never overheated, I just dont want to warp those heads.
Old Jun 26, 2007 | 01:56 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Nothing wrong with anything, just need to get a fan switch/sensor that kicks on at a lower temp. Sounds like your stocker is 220F get one that either adjustable or kicks on at a lower temp like 195F
Old Jun 26, 2007 | 07:16 PM
2broke2gofast
But am I safe running at those temps since thats the factory settings? I just dont want to warp any heads.
Old Jun 26, 2007 | 09:20 PM
blackstallion666's Avatar
blackstallion666
you should be ok but it wouldn't hurt to try and bring the temp down alittle
Old Jun 28, 2007 | 11:07 PM
dadoordude's Avatar
dadoordude
Possibly the guage, warm it up and use acandy thermometer, (I hope that is spelled right) stick it in the radiator and see what it shows, AFR heads are 6061 T-6 aluminum and are heat treated, to the "T-6" ie heat treat, not much of a chance to warp them if torqued properly.
Old Jun 29, 2007 | 09:48 AM
2broke2gofast
thanks to all
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
