1964 289ci 4.7 Problem
Old Jul 25, 2007 | 02:20 PM
4.698GT's Avatar
4.698GT
Default RE: 1964 289ci 4.7 Problem
get a cooling system pressure tester and do a test. that will determine if you have a leaking gasket. Next thing you have to do is find which one is leaking.
Old Aug 27, 2007 | 10:51 AM
BC84's Avatar
BC84
Found out, that the intake manifold gaskets are blown, 2 pistons are cracked an the left heat cracked!
Think, that it will be better to buy a new engine than rebuilt this one and a new transmission!?
Looking for an Edelbrock Performer 9.0:1. But don't know where to buy it.
What engine do you think will be good to built in?
Cheers
Christian
Old Aug 27, 2007 | 09:14 PM
Chubstang's Avatar
Chubstang
I would say get a 302 crate motor which can be had for pretty cheap, unless you want to keep the car original.
Old Aug 27, 2007 | 10:50 PM
JMD's Avatar
JMD
ORIGINAL: mustangman5089
If you put in a new engine, you will need a bell housing also. 1964 used a 5 bolt bellhousing, all years after used a 6 bolt bell housing.
Considering the condition of your engine, a new one would be a good idea. The cracks might indicate a bad overheat in the past.
Old Aug 28, 2007 | 05:35 AM
BC84's Avatar
BC84
It's not a Mustang car, but a Ford F100 1954. It's just the engine of a Mustang.
Cheers
Christian
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
SilverStallion05
Sep 5, 2015 10:48 AM
