351W specifications help
Old Jan 12, 2005 | 07:42 PM
saleen351mike's Avatar
saleen351mike
Default 351W specifications help
what is the Cylinder Bore Size and The Piston Stroke Length of an unmodified 351w block?
also, can someone discribe in as much detail as possible the Combustion Chamber Volume and the Piston Deck Clearence.
any info will greatly help in doing calculations.
thanks alot guys
mike
Old Jan 12, 2005 | 08:23 PM
C/Note's Avatar
C/Note
I ♥ Acer
Default RE: 351W specifications help
ORIGINAL: saleen351mike
thanks alot guys
mike
4.00 bore 3.50 stroke,,,,,=351.....heads depends on which head you going with???stock late model heads around 68cc..some heads or 60 cc like the edel rpm or victor jrs ,,,a 351w with a flat top with 60cc head compression is 10.7 to 1...deck height is 9.500,,,heres a pic
[IMG]local://upfiles/10419/DB2060E330D1467D819AAF7D771A10A3.jpg[/IMG]
Old Jan 13, 2005 | 07:08 PM
saleen351mike
wow, thanks bro. that is what I needed.
later, mike
Old Jan 13, 2005 | 07:16 PM
C/Note's Avatar
C/Note
I ♥ Acer
later, mike
no problem heres my proof
[IMG]local://upfiles/10419/30F6A71554DB4BD9B81DEC578129226E.jpg[/IMG]
Old Jan 15, 2005 | 02:17 AM
import slayer's Avatar
import slayer
Don't forget that some early 351w blocks had a 9.2 deck height.
Old Jan 15, 2005 | 02:50 PM
C/Note's Avatar
C/Note
I ♥ Acer
ORIGINAL: import slayer
no they didnt ,,they got after market blocks with 9.500 and 9.200 deck height,,earlier ones had 9.480...check it out!
vargas
Jun 17, 2017 12:17 PM
Ken_in_d
Apr 15, 2016 02:25 PM
guitarman376
Sep 30, 2015 05:54 PM
LiquidDrink
Sep 29, 2015 10:06 AM
treesloth
Sep 28, 2015 07:03 AM
