Help me! Ait conditioning Problems
Old Jul 5, 2007 | 11:42 PM
swingc's Avatar
swingc
Default Help me! Ait conditioning Problems
I have a 98 Mustang 3.8L. This afternoon, when I turned on the A/C to MaxA/C, the vent blow out the warm air, and the temperature became higher and higher. The temperature controler is at the end of cold ( blue) , no cold air comes out but very hot air and the temperature is very higher than the air outside. It lools like turning on the heat. But yesterday, it worked fine. What is the problem?
Old Jul 6, 2007 | 03:34 AM
Janky Hoopty's Avatar
Janky Hoopty
Default RE: Help me! Ait conditioning Problems
I justed experienced a problem very similar to this. In the hotter parts of the day my air condenser would disengage would not even turn. but when it cooled off it kicked right back in and worked fine. Try looking under the hood with the car on, and a/c on and see if your air condenser is working properly. I had to have mine replaced because it was on the brink of seizing up. After replacement, everything worked fine.
Old Jul 6, 2007 | 11:39 AM
Chopper's Avatar
Chopper
The A/C freon charge is probably low and will need to be refilled.The COMPRESSOR will cycle on and off quickly without cooling the air when the refrigerant leaks out.If there are leaks you will have to get them fixed or you'll be adding freon forever.
You can buy a recharge kit at any auto parts store,just make sure it's for the R-134-A freon and not the old R-12.If you want to fix any leaks you can use a florescent dye and an ultaviolet light to find the leaks.
Old Jul 6, 2007 | 11:45 AM
TwotoneVert's Avatar
TwotoneVert
ORIGINAL: Chopper
Chopper is right. Its the low pressure switch. Add some freon.
Old Jul 6, 2007 | 06:14 PM
swingc's Avatar
swingc
Thank you guys, i will go to add some freon first.
Old Jul 6, 2007 | 09:28 PM
swingc's Avatar
swingc
I went to the mechanical shop to check it. They add the freon and florescent dye, and the A/C works. But they charge me $110 for that, a xxx bad shop!
Old Jul 7, 2007 | 03:35 AM
mudvayne1's Avatar
mudvayne1
Wow 110 bucks? wow. They had to have made at least 50 dollars profit off that.
Jb145700
Aug 21, 2022 06:37 AM
McLeary
Mar 14, 2016 07:50 PM
yourmom6990
Sep 14, 2015 10:52 PM
dunebuggydude11
Sep 13, 2015 03:03 PM
fastbackford351
Sep 12, 2015 09:42 AM
