Can running rich cause damage?
Old Jan 17, 2005 | 05:03 PM
Fallstar01's Avatar
Fallstar01
Default Can running rich cause damage?
I get the feeling that my car is running very rich (whiter smoke, worse gas milage, and when I installed my TB I noticed that the whole intake tube had a thin layer of black funk). Can this cause any long term damage? (Wondering if I should stick a dyno tune on the credit card).
Old Jan 17, 2005 | 08:02 PM
fordguy17's Avatar
fordguy17
Default RE: Can running rich cause damage?
i know i will foul up youtr spark plugs and probably leave deposits in your engine too. check your o2 sensors.
Old Jan 17, 2005 | 08:22 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Over time it will hurt but its a whole lot better to run rich than it is to run lean.
Old Jan 17, 2005 | 08:26 PM
Chopper's Avatar
Chopper
ORIGINAL: Fallstar01
Rich smoke is blacker instead of whiter.I just installed a 75 mmTB and plenum,has this caused you to drive"differently"???The black funk is probably oil mist and blowby from the crank case coming through the PCV that has accumulated over time.It can cause idle and startup problems if left to build up.Mileage is hard to figure just driving around town or short trips.I drive 50 miles each way to work and get about 29+ mpg.This was measured with "grandma like" driving habits.One hard pass and that cut 1 mpg off a tankfull,so if you do more"passing"than before this is likely the problem.Also, cold weather will eat up more gas because of extended warm up time.Only use a credit card if you already have the money to pay the bill when it gets back home.
Old Jan 18, 2005 | 12:56 AM
Dan04COBRA's Avatar
Dan04COBRA
Yeah, white smoke isn't from running rich. You could have some leaky head gaskets. Running real lean can get ya some white smoke while she's seizing up heh. Running rich will fry O2 sensors in no time, destroy your cats, destroy spark plugs...kill gas mileage...
Old Jan 18, 2005 | 01:02 AM
bobby's Avatar
bobby
it wont really harm your motor just gumit up
Old Jan 18, 2005 | 09:09 AM
horseshoeing's Avatar
horseshoeing
If you run a MSD, they tell you to run it a little rich.
Old Jan 18, 2005 | 02:53 PM
vfast's Avatar
vfast
I ♥ Acer
if you wash down the cyl walls with gas..not good
Old Jan 18, 2005 | 03:27 PM
horseshoeing
Don't that kill a diesel? Thats why they have glow plugs.
Old Jan 18, 2005 | 04:47 PM
Fallstar01's Avatar
Fallstar01
I'm idling a little higher as well and the sound of the engine isn't that ultra clean smooth idle that I'm used to which is why I think I've been running rich. I'm also not 100% convinced that my MAM is the best calibrated for my injectors which may be another reason I'm using so much fuel.
