Can running rich cause damage?
Old Jan 18, 2005 | 06:20 PM
bobby's Avatar
bobby
Default RE: Can running rich cause damage?
ORIGINAL: horseshoeing
If you run a MSD, they tell you to run it a little rich.
y's that?
Old Jan 18, 2005 | 06:48 PM
vfast's Avatar
vfast
I ♥ Acer
really..I don't believe MSD says that
Old Jan 18, 2005 | 08:59 PM
bobby's Avatar
bobby
anyone else kow about this?? i dont think they say that, if anything it would burn cleaner..............................
Old Jan 19, 2005 | 10:38 AM
horseshoeing's Avatar
horseshoeing
ORIGINAL: bobby
y's that?
You can burn your valves if you don't, I heard.
Old Jan 19, 2005 | 05:59 PM
bobby's Avatar
bobby
WOW, never knew that one.....
Old Jan 19, 2005 | 06:38 PM
horseshoeing
A MSD burns all of the fuel and can run a motor lean so I am told.
Old Jan 19, 2005 | 06:53 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
Don't that kill a diesel? Thats why they have glow plugs.
that destroys deisels. and bad turbo bushings/bearings puking oil into the intake. if you see black smoke on a deisel that is unburned fuel. glow plugs are used to heat up the air so it burns better. they are compression ignition, no sparkplugs or ignition system, and the hotter the air the better the burn. a turbo deisel will have a compression of at least 16:1, a non-turbo 20-28:1
Old Jan 19, 2005 | 07:44 PM
bobby's Avatar
bobby
ahhhhh, that makes perfect sense
Old Jan 20, 2005 | 12:17 PM
Tims 88GT's Avatar
Tims 88GT
white smoke is a bad thing check your oil cap on valve cover look at the bottom and hope its not white/gray because that is exactly what happend to me i blew a head gasket.
Old Jan 20, 2005 | 12:21 PM
horseshoeing
ORIGINAL: matthockey32
Glow plugs heat it up to 180F when you start it and when it cold (when you 1st start it) on some trucks.
Jb145700
Aug 21, 2022 06:37 AM
Nick Oliver
Oct 17, 2018 04:22 AM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
Art161
Sep 9, 2015 10:33 AM
