battery install
Old Jan 18, 2005 | 03:24 AM
1990silverlx5.0's Avatar
1990silverlx5.0
Default battery install
I would like to install the battery in my hatch to assist in weight transferrance, i understand that i will have to use an optima type battery however what type of fuse or breaker do I use? I have enough cable to run from the battery to the starter solenoid but i am unsure of how to fuse it, any help would be greatly appreciated
Andy
Old Jan 20, 2005 | 01:58 PM
roundman's Avatar
roundman
Default RE: battery install
there is no fuse installed in the line from the postive battery post to the starter solenoid. and you can use any type battery you want if you install it in a battery box and vent the box to the outside of the car. bear in mind if you do take the car to the strip with the battery relocated to the back like this, you will need a master battery shutoff switch mounted on the rear of the car and clearly labeled for the OFF position in order to pass tech at the strip. and the battery must be held down with at least two 3/8" diameter hold downs securely bolted into the floorboard of the vehicle. you can get battery boxes made of metal or poly and switches from Summit Racing or Jegs.
Old Jan 21, 2005 | 08:09 PM
vfast's Avatar
vfast
I ♥ Acer
try e-bay for the box as you'll save some $$$ roundy I think has become a saleman for summit*L*.... one thing about the kits is I think the pos cable is too small most use a 2 gauge...I use a 00 gauge but a 0 gauge will work great...also I would buy the largest amp battery you can get in the box. i think you wil have no problem finding a 750 amp
Old Jan 21, 2005 | 09:32 PM
roundman's Avatar
roundman
I'm sure with my vast mutual fund holdings I must own some stock in Summit and maybe Jegs and Ford and ......................LOL
Old Jan 21, 2005 | 09:52 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
I don't know how relevant it is where you are going to race but Moroso is the only battery box approved by NHRA.
Old Jan 21, 2005 | 10:02 PM
vfast's Avatar
vfast
I ♥ Acer
sorry my friend there are others...
Old Jan 21, 2005 | 10:48 PM
luckythirteen13's Avatar
luckythirteen13
i thought there were a wide range to choose from.....
Nurdyguy
Jan 20, 2025 04:38 PM
mtgldr
Feb 3, 2024 09:00 PM
Art161
Sep 9, 2015 10:33 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
