Transmission cooler
Old Jan 20, 2005 | 03:29 AM
  #21
import slayer's Avatar
import slayer
Default RE: Transmission cooler
I'm not sure how much pressure is through those lines but I used tranny hose which is high pressure hose. Hose clamps will hold the hoses to the cooler though. As far as your gauge goes, I don't have one of those so I really don't know where to tell you to put one.
My guess would be to put it somewhere after the cooler so that you know the temp. of the fluid that's going back through the tranny.
Yes, you can trim the lines down as much as you need.
Bobby, I used brass pipe fittings to block off the holes in the radiator. I forget what size they are but you can get them at a hardware store. Take the end of an old tranny line with you and tell them you need a pipe fitting that same size thread.
Old Jan 20, 2005 | 01:12 PM
  #22
roundman's Avatar
roundman
I used the B&M racing model tranny oil cooler, it sells for about $80 or so and comes with 1/2" NPT female threaded connections.
I used some 1" x 1/8" aluminum flat bar to make two brackets to mount it on and installed the brackets with bolts in holes drilled in the upper and lower radiator support so the cooler sits out a couple of inches in front of the radiator. I then cut the factory tubing down where the lines are running flat going toward the radiator and installed tubing couplings on them and ran new hard lines from the couplings to the two connections on the cooler so there are no hoses used at all. you can get the necessary tubing and pipe fittings at most good hardware stores including the brass plugs necessary to plug the openings to the old cooler in the radiator.
as far as reading the tranny oil temperature, you want to know the temperature of the oil in the tranny oil pan, not the temp coming from the oil cooler. you can get a bulkhead fitting and drill a hole for it in the tranny pan and install the temperature sensor for a temp gauge in this fitting in the tranny oil pan which is what I did with mine. just make sure to pick a location on the pan where the probe won't hit anything when it is inserted into the oil pan.
Old Jan 20, 2005 | 07:36 PM
  #23
bobby's Avatar
bobby
thanks a lot!
Old Jan 20, 2005 | 10:43 PM
  #24
luckythirteen13's Avatar
luckythirteen13
which line is the sending line and which line is the recieving line? is the one that goes to the top of the radiator the sending?
Old Jan 20, 2005 | 11:34 PM
  #25
bobby's Avatar
bobby
ORIGINAL: luckythirteen13
i believe soo
Old Jan 21, 2005 | 01:27 AM
  #26
91LXstanger's Avatar
91LXstanger
Dammit!...u guys got any pics with it installed??. I wanna get one now.lol.
Old Jan 21, 2005 | 02:05 AM
  #27
luckythirteen13
should be very easy, im going to order mine tomorrow
i got impatient, i ordered it just now
Old Jan 22, 2005 | 06:00 PM
  #28
import slayer
ORIGINAL: 91LXstanger
I'll see if I can take a shot of mine for you.
Old Jan 22, 2005 | 07:08 PM
  #29
91LXstanger
cool, that would be great bro.
Old Jan 22, 2005 | 08:05 PM
  #30
import slayer
I'll try to get it done tomorrow(sunday) before the football games begin.
