Transmission cooler
Old Jan 18, 2005 | 08:06 PM
Choppa's Avatar
Choppa
Default Transmission cooler
ive seen them aournd and stuff then the advertised one on Horsepower Tv(u kno on spike tv) it was only like 30 bux im wondering if they really make a difference and how much of one? How do u hook them up? let me kno if ne of u have one or kno about them
thanks
Old Jan 18, 2005 | 08:42 PM
import slayer's Avatar
import slayer
Default RE: Transmission cooler
It's one of the best things you can do for your tranny....period!
Hook up is simple: simply mount the cooler where it will get the most air and run the lines that used to go to the radiator to the new cooler....done. You need high pressure hose to connect the steel lines to the cooler.
Old Jan 18, 2005 | 08:58 PM
bobby's Avatar
bobby
can you mountit in fron of your a/c condenser?
Old Jan 18, 2005 | 09:20 PM
import slayer
You prolly could. I have mine mounted in front of the radiator and it seems to be ok.
I have it in the lower corner so I could keep as much of the middle section of the radiator open for air flow.
Old Jan 18, 2005 | 09:36 PM
bobby's Avatar
bobby
ok gotcha, hey, how does it mount?
bobby's Avatar
bobby
ORIGINAL: bobby
i mean, how does it attach to the radiator?
Old Jan 18, 2005 | 09:53 PM
luckythirteen13's Avatar
luckythirteen13
thats it?!?!? you just hook it to the lines that are already running to the regular radator? thats easy. do you have to plug the holes in the radiator where the lines came from?
Old Jan 18, 2005 | 10:41 PM
import slayer
Yes, you need to plug the old holes. I used two small pipe fittings.
My cooler came with two long, nylon, threaded mounts that you put through the radiator fins.
I know that sounds dangerous by passing them through the radiator fins but it's ok.
You don't have to mount it on the radiator like that though. I've seem them mounted on the sides of radiator supports. As longs as it's in the path of cool air, you can put them anywhere.
Make sure you use high pressure hose. They make tranny hose for this.
Old Jan 18, 2005 | 10:46 PM
bobby's Avatar
bobby
ORIGINAL: import slayer
so stock radiator comes with a trany cooler?
Old Jan 18, 2005 | 10:53 PM
import slayer
ORIGINAL: bobby
No....where did that question come from???????
