A BRAIN TEASER!
Old Jan 19, 2005 | 08:50 PM
C/Note's Avatar
C/Note
I ♥ Acer
Default RE: A BRAIN TEASER!
i need a gallon in 20 seconds to run 9s..thats what www.barrygrant.com says
Old Jan 19, 2005 | 09:41 PM
FoxGT's Avatar
FoxGT
24 in parallel, 12 in series.
Old Jan 20, 2005 | 01:32 PM
roundman's Avatar
roundman
ORIGINAL: hotrodmanII
12 psi. pumps in parallel like that double the volume but the pressure remains the same. if you install the two pumps in series where the outlet of one becomes the inlet of the next one, then the flow would only be that of one pump but the pressure would be doubled when connected in series. this is how deep well pumps are made, small impellers connected in series where one pump discharges into the next one and the next one etc. to develop sufficient pressure to overcome the head losses in getting the water up to the surface from hundreds of feet below ground level.
that 1 gal in 20 seconds means you need a pump system capable of 180 gal/hour total flow. and the lines need to be large enough so the pressure drop is kept to a minimun also from the pump(s) to the carb. I would go with at least 3/8" or better yet 1/2" diameter lines for this.
Old Jan 20, 2005 | 07:36 PM
bobby's Avatar
bobby
how much hp u got nos?
Old Jan 21, 2005 | 08:21 PM
C/Note's Avatar
C/Note
I ♥ Acer
ORIGINAL: roundman
well this is what i got #6 AN hose from pumps,,to Y BLOCK ,,then from there i got #10 AN on the 1 out side...i havent done the volume check yet ,,cause they gave me a wrong adapter fitting i will know tommorrow,,,,#10 is big round as a 3/4 heater hose..[&:]
Old Jan 21, 2005 | 08:30 PM
vfast's Avatar
vfast
I ♥ Acer
dumass here just wants us to figure it out
Old Jan 21, 2005 | 08:59 PM
roundman's Avatar
roundman
#6 AN hose is .344" inside diameter and #10 AN hose is .562" inside diameter so they should be large enough I would think.
Old Jan 21, 2005 | 10:05 PM
vfast's Avatar
vfast
I ♥ Acer
damn gramps you do have to much time on your hands...ya want something to do? I'll haul my 72 monte down thier and you can strip it down..I mean the paint
Old Jan 22, 2005 | 02:03 PM
C/Note's Avatar
C/Note
I ♥ Acer
ORIGINAL: vfast
i guess you dont know![sm=icon_blah.gif][sm=icon_blah.gif][sm=icon_blah.gif][sm=icon_blah.gif][sm=icon_blah.gif][sm=exactly.gif][sm=joke.gif]
Old Jan 22, 2005 | 02:25 PM
vfast's Avatar
vfast
I ♥ Acer
yes batman I know
