A BRAIN TEASER!
Old Jan 19, 2005 | 12:54 AM
C/Note's Avatar
C/Note
I ♥ Acer
Default A BRAIN TEASER!
look at this pic..got 2 fuel pumps with 12 psi each going in ..what is the pressure coming out ...? 12 psi or 24 psi...?
[IMG]local://upfiles/10419/F08B083F539A4C3F878AEE6719902AD2.jpg[/IMG]
Old Jan 19, 2005 | 01:24 AM
Jugador's Avatar
Jugador
Default RE: A BRAIN TEASER!
i think 16 psi by this logic. add up the incoming diameters (3/8+3/8) and divide the outlet (1/2) by that to get the ratio (2/3) of what's actually being put out. then multiply that by the incoming pressure (24) and it comes out to 16 psi. can anyone verify that?
Old Jan 19, 2005 | 02:06 AM
luckythirteen13's Avatar
luckythirteen13
12psi. if each pump makes 12psi, your combined pressure will be 12. even though you have two 3/8" inlets and one .5" outlet, you wont get more pressure, you are just choking the flow. choking the flow will not increase pressure, it will just constrict flow
Old Jan 19, 2005 | 02:07 AM
Pacman's Avatar
Pacman
the answer is 84kpa, 12psi. it doesnt double.
Old Jan 19, 2005 | 02:12 AM
Jugador's Avatar
Jugador
wait i was thinking about this again. if the incoming pressure is gonna stay a constant 12, but it has to fit in a smaller hole, then the pressure has to increase to fit it through doesnt it? cause the fuel isnt gonna back up, its gonna keep coming at 12psi
Old Jan 19, 2005 | 06:00 PM
bobby's Avatar
bobby
12psi
Old Jan 19, 2005 | 07:00 PM
uedlose's Avatar
uedlose
12psi
Old Jan 19, 2005 | 07:07 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
the pressure will exceed 12 PSI in the smaller tubes and therefore the larger tube will exceed 12 PSI as well.
Old Jan 19, 2005 | 07:31 PM
89stanglx's Avatar
89stanglx
it would still be 12 psi. The two pumps would be capable of more GPM than 1 pump.
Old Jan 19, 2005 | 07:42 PM
bobby's Avatar
bobby
still 12 psi
