65 transmission problem
Old Jul 16, 2007 | 02:41 PM
65PonyLove's Avatar
65PonyLove
Default 65 transmission problem
I just recently had my motor rebuilt and when I went to drive it the tranny didnt shift like it should. Its a 3 speed automatic with a stage 2 shift kit in it. I had the tranny rebuilt like seriously 5 years ago. But mileage wise probably only like 2000 AT THE MOST!! So wear and tear isnt an issue,I dont think??? Anyway, it shifts hard into 2nd but when I get on the throttle and try to shift it into drive it ACTS like it goes into nuetral (revs really high for a split second) then "slips" into drive. I took the pan off to change the fluid and filter andI noticed aspring and a little brass cup/nipple....piece that fell out....I'm sure this is the reason why it doesnt shift correctly, but do I need a full rebuild??
Thanks, I'm new to the forum so anything is nice
Blake
Old Jul 16, 2007 | 08:14 PM
turboblast's Avatar
turboblast
Default RE: 65 transmission problem
its probably a part from the valve body andits not getting enough pressure to engage the 3rd clutch or band. Take the parts to a tranny shop and they can tell you what they are. It may be a quick fix to the valve body. Just don't keep driving it like that because it will probably burn up the clutches if there is not enough pressure to fully apply them
Old Jul 17, 2007 | 01:52 AM
65PonyLove's Avatar
65PonyLove
thanks, good to know. AndI actually took it to a shop today and thats exactly what they said.....I have an appt thursday to take it in. Thanks for the quick response
[/align]
Old Jul 17, 2007 | 05:25 AM
turboblast's Avatar
turboblast
Good luck
Old Jul 17, 2007 | 07:41 AM
Stu's Avatar
Stu
If you removed the filter the valve and spring will fall out.
The valve goes into the body, then the spring.
It is held in by the filter.
04stangman
Sep 26, 2015 09:33 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
