fuel pump
Old Jan 19, 2005 | 05:33 PM
jtd19905.0's Avatar
jtd19905.0
Default fuel pump
hi everyone im new here.just bought a 1990 5.0 mustang about a 2 mouths ago.anyway heres my problem.last night i shut the car off and i could hear the fuel pump still running and it won't shut off unless i disconnect the batt.any help would be great thanx jtd
Old Jan 19, 2005 | 06:36 PM
horseshoeing's Avatar
horseshoeing
Default RE: fuel pump
I will take a stab at this. Could your contacter for your fuel pump be stuck?
Old Jan 20, 2005 | 01:37 PM
roundman's Avatar
roundman
there are two possible sources of this problem, one is the fuel pump relay mounted under the driver's seat and the other is the ECU which gets a signal from the engine that tells it when the engine is running and this allows the ECU to signal the pump to run via the pump relay. if the ECU ain't seeing the engine turn off, then it won't shut off the fuel pump like it should. try replacing the relay first and see if this fixes your problem.
Old Jan 20, 2005 | 02:20 PM
jtd19905.0's Avatar
jtd19905.0
that was my next question where's the relay.thanx for your help roundman i'll try that.
Old Jan 20, 2005 | 03:23 PM
jtd19905.0's Avatar
jtd19905.0
thanx again roundman it was the relayand thank you horseshoeing.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
