noise from rear
Old Jul 18, 2007 | 01:36 PM
dan's Avatar
dan
Default noise from rear
A while ago i was in a minor accident where i hit a snow bank. My rear left wheel took all of the brute, and i was going about 30. I took it to the shop where they fixed some minor body damage for about 1500. They popped the tire back onto the wheel. Ever since, there has been an ocational noise that only occurs (or is noticeable) when i drive under 5 mph.It sounds like a tapping noise, uccuring at a frequency of about 3 taps/ second (at 5 mph). Sometimes it doesn't happen, but sometimes it does. It sounds almost like my tire is catching on something and then breaking free, but we can see no clearance issues when looking underneith. I hope i didn't f up my rear. Any advice?
Old Jul 18, 2007 | 07:46 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: noise from rear
Have a shop check to make sure your rear is straight. Could be bent.
Old Jul 18, 2007 | 11:04 PM
Blckstng93's Avatar
Blckstng93
Hopefully its not the rear itself. Do you feel anything along with the noise? Could be a bent axle shaft. Have somebody follow you to see if the tire wobbles on that side. If it wobbles you need a new shaft. I did just that a few years ago. A bent rear however can be straightened so dont freak.
Old Jul 19, 2007 | 01:17 PM
dan's Avatar
dan
i don't believe i can feel anything with the noise. If my tire was wobbly, wouldn't i notice this at high speeds?
Old Jul 20, 2007 | 03:50 AM
wolfheads's Avatar
wolfheads
You can't always feel the wobble of a bent faceplate of the axle. I have a 71 mach that was involved in a simular accident and I had the same problem. I didn't notice any wobble until I got it on a rack and put it in gear. It was a simple and inexpensive process to replace.
bjdutch2005
Mar 24, 2017 03:38 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Emblazoned
Sep 3, 2015 10:45 PM
Sep 1, 2015 08:16 PM
