Key cylinder cam loose, how to fix it? help
Old Jan 22, 2005 | 07:20 PM
veloci1's Avatar
veloci1
Default Key cylinder cam loose, how to fix it? help
Today after closing my door the key cylinder popped out of the door. I looked for the clip that keeps it in place but i could not find it. I will be going to the deler to get the clip, but i need to know how to get the clip behind the key cylinder. can anyone help?
thanks
Old Jan 22, 2005 | 07:57 PM
Chopper's Avatar
Chopper
Default RE: Key cylinder cam loose, how to fix it? help
You must remove the door panel.They are held on with clips that you pry loose with a screwdriver or you can get a special tool from any auto parts store.
Old Jan 24, 2005 | 02:49 PM
roundman's Avatar
roundman
the clip you need is probably lying around in the bottom of the door, so take the interior panel off and look around inside the bottom of the door for it, you might need a magnet to retrieve it if your hand won't fit down in the bottom of the door.
bconboy
Sep 21, 2015 12:52 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Mikett
Sep 12, 2015 10:52 PM
