Just looking for some help
Old Jul 26, 2007 | 12:49 AM
NZ94Stang5.0's Avatar
NZ94Stang5.0
Default Just looking for some help
I'm in the process of looking at a 95 gt that is heavily modded and im wondering what #'s it should put out?? Here are the mods
Rebuilt E7e heads w/ new valves, stems, seals, comp cam springs, keepers and gaskets
- Cobra upper and lower intake w/ 2 inch spacer
- Holley powerseries 70mm TB
- Cold air w/ 75mm Pro M mass air relocated to inside fender
- Ford racing #24 injectors, ford racing 1.7 rockers, ford racing roller lifters and Comp cam valve springs
- Ford motorsport E303 cam
- BBK shortie headers and MAC x pipe no cats
- MAC flow tubes welded to flowmaster 40 dump mufflers
- MSD 6AL box, MSD coil and MSD cap and rotor
- Taylor 9mm wires
- caster camber plates
- New dubble roller timing chain
- New harmonic balancer
- Alum driveshaft
- Alum radiator
- 3.73 gears and posi
- Rebuilt T5 w/ hardened shafts, sycros, springs, shims and solid 2nd gear blocker
- Centerforce dual friction clutch and new flywheel
- Steeda Tr Ax short shifter
- Energy susp poli bushings upper and lower arms
- Pro M PIH harness for fan control system
jw about hp/tq and estimated qt mile times
Old Jul 26, 2007 | 01:01 AM
NZ94Stang5.0
Default RE: Just looking for some help
just looking for ballpark numbers
