Project Mustang
Old Jul 26, 2007 | 11:22 AM
MrP's Avatar
MrP
Default Project Mustang
Sooo, I'll be graduating from school soon and I'll finally be making money...
I would like to build up a Notchback Mustang but I have not a clue where to start except for the body...
Here is what I would like to see out of the Stang...
Capable Daily Driver...
Pump Gas....
Low 11 second quartermile..
High top-end...
I'm not too familiar with Ford Engines and Trannies...
Perhaps you guys could share your info on your builds or give advice...
Thanks!
Old Jul 27, 2007 | 11:01 AM
Ahnial8u's Avatar
Ahnial8u
Default RE: Project Mustang
If you have the money forge the internals and then get a nice turbo setup. With about 10 LBS on a "stock" motor even you should see 400 RWHP when needed.With a built motor skies are the limit. Plus with a Turbo setup you will be banging up top mostly.You could always build a Stroker with a good H/C/I combo and some suspension work and probably dip into the 11's. Good luck
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
kiwi4100
Aug 18, 2015 10:45 AM
kiwi4100
Aug 16, 2015 08:39 PM
daytooday
Aug 11, 2015 09:22 AM
