88 5.0 wont start
Old Jul 27, 2007 | 10:36 PM
firehawk316's Avatar
firehawk316
Default 88 5.0 wont start
my 5.0 wont start i turn the key and it will make a single click. i changed the clutch safty switch starter soleinoid and ignition switch . Im running out of ideas please help
Old Jul 27, 2007 | 11:19 PM
davesyo's Avatar
davesyo
Default RE: 88 5.0 wont start
What about the battery ? Did you check the voltage ? could also be a bad connection or a bad cable
Old Jul 28, 2007 | 06:12 AM
corvetteguy's Avatar
corvetteguy
I would start by removing each cable from the battery
to the solenoid and wire brushing each till it
is real shinny. Then reconnect good and tite.
If still no-go I would apply 12 volts to the small wire on
the solenoid and see if the motor turns over. Make sure
in NEUTRAL with BRAKES ON.
If still no-go I would apply 12 volts directly to the
starter motor.
If still no-go I would go down to the
starter and
make sure the connections are clean and tight.
If no-go I would suspect the starter.
Old Jul 28, 2007 | 06:59 PM
oachs83's Avatar
oachs83
I have had this problem on two of my Foxes. There is a smaller ground wire that branches off of the ground wire on the battery. That smaller wire is then about 6-10 inches long and bolts to the drivers side fender. That sometimes gets loose and/or coroded.. just a suggestion good luck.
Granatelli Sales
Mar 25, 2016 08:01 PM
2007StangV6
Jan 28, 2016 06:09 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
Emblazoned
Sep 3, 2015 10:45 PM
5.0 kevo
Sep 3, 2015 06:24 PM
