simple mustang, simple problem, simple fix?
Old Jul 30, 2007 | 01:57 PM
izzapac's Avatar
izzapac
Default simple mustang, simple problem, simple fix?
I drive a 96 Standard Mustang, 3.8 V6, and havent had much problems with it, until lately. Temperature gauge has been redlining within 5 minutes (+/-) of 45-50mph driving. My unknowledgable self decided to fill the resevoir with extra water. Now Im overfilled with water. Upon opening the actual radiator cap, I found it to be near empty. I cant seem to find where to drain my radiator, and use the hose to flush it, and all that good stuff, I've done a good bit of reading about the procedure, I just cant find the petcock valve. Any info is much appreciated. (First time poster btw). Thanks in advance
-Kenny
Old Jul 30, 2007 | 04:34 PM
90lxstang's Avatar
90lxstang
Default RE: simple mustang, simple problem, simple fix?
Welcome to the forums Kenny. I can't answer your question myself, but post this question in the V6 section of the forums. I'm more than positive a few people there can help you easily.
Old Jul 30, 2007 | 04:35 PM
Murdoc's Avatar
Murdoc
I ♥ Acer
your t-stat may be bad or your radiator could be taking a dump on you.
Old Jul 30, 2007 | 05:13 PM
945LSTANG's Avatar
945LSTANG
sounds like a leak.
Old Jul 30, 2007 | 05:21 PM
Titan5.0's Avatar
Titan5.0
ORIGINAL: 945LSTANG
sounds like a leak.
But he said it's now overfilled...wouldn't that point to a bad t-stat. I've had the samesymptoms with my 5.0 and the t-stat was sticking shut. Just my .02
Old Jul 30, 2007 | 05:23 PM
945LSTANG's Avatar
945LSTANG
ORIGINAL: izzapac
-Kenny
sounds like a leak.
Old Jul 30, 2007 | 05:26 PM
Titan5.0's Avatar
Titan5.0
Easy answer then, hey Izzapac, any puddles?
Old Jul 30, 2007 | 05:28 PM
945LSTANG's Avatar
945LSTANG
ORIGINAL: Titan5.0
could only leak under pressure, such as when he is driving. that would explain no puddles.
Old Jul 30, 2007 | 06:58 PM
Chopper's Avatar
Chopper
This is easy.Take the radiator cap off and start the engine.Let it idle until it reaches operating temp.If the coolant circulates normally you're loosing coolant somewhere.Maybe a slow head gasket leak.
If no coolant circulates but steam comes out it's probably the T-stat.
Beware of live steam suddenly shooting out of the open radiator.
Old Jul 30, 2007 | 08:53 PM
Titan5.0's Avatar
Titan5.0
ORIGINAL: 945LSTANG
ORIGINAL: Titan5.0
I see what your saying 94lstang, but I just don't see why he would bother to mention that his tank is overfilled if it was a leak. He could just drive it and it would leak out no problem. My money's on a t-stat, but you could be right as well. Just do like Chopper said and you'll know for sure then. Good luck!
