dumb question
Old Feb 3, 2005 | 02:49 PM
  #21
Birdieman4's Avatar
Birdieman4
Default RE: dumb question
A 4.10 don't put more stress on you drivetrain. Its easyer to turn, so how could that put more stress on your drivetrain? Now how you drive it can put stress on you drivetrain
They put more stress on your drivetrain and clutch because: 1) with short gears you are shifting more, thus using more clutch, which will shorten the clutch's life. 2) You are in higher rpm ranges more often, which puts more stress on the engine and drivetrain.
With 4.10's on the freeway, your engine is at a higher rpm than with taller gears, which over time can make some difference, provided you are on the freeway a lot. I agree with daGGer on this one: if you aren't on the freeway as much do 3.73's. If you are on the freeway more, do the 3.55's.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
